Ok I will try to describe this problem... Shifted into 1st gear and drove off of a small curb from the grass i was parked on (very slowly and ive done it before). I got a horrible vibration in the shift knob like the spinning drive shaft was hitting it (metal on metal clanking) causing the shift knob to move up and down violently. So I pulled over and noticed the shifter is loose and unable to use 1st or 2nd without the horrible shaking. I was able to shift into 3rd and drive away, but somewhere i hit a small bump and the horrible clanking of the shifter on the drive shaft returned. I pulled over immediately and was able to shift into 4th gear at this point without the clanking and make it all the way home. Whats going on here?
Cant use 1st or 2nd gear. Drove home in 3rd and 4th. - Slothboy214:54:32 05/12/18
